A/C griding/squeeling noise
p150rulz
03-05-2006, 09:56 PM
I have a 1997 GTP. I've been hearing a grinding noise (and really loud squeeling at times )noise from time to time when the heat or air is running. It only does it every once in a while, it's not every time I turn it on, but it won't run but just for a little bit before it starts making the noise again.
What would be causing this? Has anyone else experienced this?
BNaylor
03-06-2006, 06:27 AM
If the noise is coming from under the passenger side of the dash it sounds like you have a bad HVAC blower motor. Probably the bearings. It is not that difficult to replace DIY.
p150rulz
03-06-2006, 09:56 AM
Is there a site or somewhere I can get a step by step on how to do that?
BNaylor
03-06-2006, 10:17 AM
Move the passenger side seat back for room.
First look on the passenger side below the glove box you will see 3 plastic press pins on the kickpanel. You need to remove the 3 press pins and kick panel can be removed.
Looking underneath you will see a bracket holding a bundle of wires and a few vacuum hoses on the left side of the blower motor. This is held on with 2 screws. Remove the screws and let the bracket hang off to the side.
Undo blower electrical connector. Now remove the blower motor by removing the 3 screws/bolts (5.5mm) holding it up into the lower evaporator assembly.
p150rulz
03-06-2006, 03:10 PM
Thanks for the info. I did some research, and it looks like there are a few different blower motors. Do you know what part number it would be for my 97 GTP?
BNaylor
03-06-2006, 03:17 PM
You are welcome.
GM Part # 52489321 - manual without digital
GM Part # 52489322 - with digital climate control
