351 swap
Pimpdady753
03-05-2006, 04:52 PM
i have a 1990 gt that im going to be putting a 351 in it, i want to make it carbed, what can i take out and what will i need any thing specal or any thing. thanks.
351wStang
03-05-2006, 10:24 PM
You will need 351w swap headers for sure. Are you going to try to keep the stock hood? If so then I would suggest you get some drop mounts and good luck. As far as wiring goes get a haynes manual or something and take out the EFI harness. You will need to keep the light/accessory harness ect.
Here are a couple links well worth reading:
http://www.fast351.com/tech/351w.htm
http://www.fast351.com/tech/4cyl.htm
http://www.fast351.com/tech/fitocarb.htm
Good luck.
Pimpdady753
03-06-2006, 06:56 AM
ok thanks.
Pimpdady753
03-06-2006, 07:17 AM
this engine can be carbed right, http://cgi.ebay.com/ebaymotors/Ford-468-HP-351-Windsor-Engine-Motor-w-TFS-Heads_W0QQitemZ8043376046QQcategoryZ33615QQrdZ1QQc mdZViewItem
351wStang
03-06-2006, 11:33 AM
yep
