98 BCM Location
rogermac
03-05-2006, 04:44 PM
I need to replace the BCM on my 1992 98 Regency, but I can't locate where it is. I thought it was on the passenger-side under the dash. When I pulled the panel off, couldn't find anything that looked like the replacement
Master01
03-07-2006, 12:25 PM
In the engine compartment under the air cleaner. I think.
rogermac
03-18-2006, 12:40 PM
I looked and there isn't anything that even resembles the BCM anywhere in the engine compartment. Could it be under the dash anywhere?
tri-power
03-20-2006, 04:41 PM
Are you talking about the ECM? If you are, I believe it's located behind the glove compartment in the dash. I"m not sure, but I believe it was on the 91' 88 we serviced.
akbmotorsports
04-25-2006, 01:45 PM
my 92 98 regency climate control shows 3 dashes only and erronious warning lights[low oil, low coolant] i am thinking bcm as well, but cant find it either. my local gm dealer gave me a part number 25646510. if you have located yours, please post location so i can save what hair i have left.
