yo, do my chrome rims help wit downforce?
sv650s
03-04-2006, 01:04 AM
j/k. i've just started getting out of my "honda's will always be slow" phase and i was thinking of something, i'm not actually gonna do it since i don't have a civic but i had an idea about having a civic run single digits without an engine swap or forced induction just all motor. Most my friends think i'm fuckin crazy but when i have an idea i like to prove that it can happen. what would you do to the motor? (start off with a k20a3 si)
iVteC_PoWeR
03-05-2006, 10:15 PM
thats a hard goal ive seen a all-motor civic completely stripped and pretty much fully modded and it was in 10s...forgot which motor though im not too sure about the full potential of k20s...basically youll have to strip it completely and build the hell out of the motor and probably spray while your at it if you want single digits
sv650s
03-05-2006, 10:52 PM
can't happen, nitrous counts as forced induction
alphalanos
03-05-2006, 10:53 PM
all motor? its probably going to cost a ton. plus no traction.
justin476
03-06-2006, 04:12 AM
if you can get an all motor civic runnin' tens..you'll be laughin. good luck buds
n8zdogg
03-06-2006, 01:08 PM
Maybe single digits in the 1/8! but the 1/4!? -- Good luck.
n8zdogg
03-06-2006, 01:14 PM
BTW - number 8 on your list is great. I'd want two shots at Walker, for that whole Yenko vs. Lancer bullshit scene in part 2.
elementskater15
03-06-2006, 03:15 PM
Skunk2 has an all motor RSX running mid 9s. I think it lays down about 300whp
kris
03-07-2006, 04:56 PM
Beat me to it. The Skunk RSX has a K24 hybrid setup, running pretty high compression numbers. They do run in the nines as well.
banditkiller
03-07-2006, 05:05 PM
plus no traction Thats why turbo cars making double the horsepower only run comparative times? Why do you think the skunk 2 car is in the 9's with ONLY ~ 300 whp? turbo cars make much much more power but they have no traction. Ive seen N/a hondas go faster on street tires than ive seen boosted ones go on slicks. FYI it is doable, but will cost an arm and a leg.
S13wanabe
03-07-2006, 09:37 PM
Yep, Skunk2 is probably the only company that is consistent in the 9's and they have a million dollar budget.
sv650s
03-08-2006, 04:40 PM
does spoon make build high horsepower engines that are all motor or are they FI too?
CivicSpoon
03-08-2006, 05:12 PM
Spoon makes all motor engines, however I've never seen those ones for sale. The ones Spoon does sell are just rebuilt Honda engines that are balanced and blueprinted by Spoon, with a slightly thinner head gasket (2-ply). They don't come with cams, or higher compression pistons, etc; just an overpriced stock engine.
And Skunk2's engine isn't a k20a3 from the '01-? Si, it's a better engine to start off with. It's like someone comparing a built all motor b16a2 to a built all motor b18c5; there's a big difference in power output available. It'd be easier to squeeze the power out of the b18c5 to get to 9's than with a b16a2. Not all K-series are created equal people.
