MAF!!! need help!!
drft103
03-01-2006, 09:05 AM
ok... my redtop SR20det did not come with a MAF plug. so how do i hook up the MAF? i was thinking about cutting the connector and wires off my KA24e and tieing it into the MAF wires in the harness... but how do i know which ones? i looked on a diagram but i could only find the black and the white, but not the black and white.. can anyone help me?
also my powersteerting pump came with TWO pressure lines... is this because it possibly came off a super hicas? if so how do i eliminate that? is it safe to just plug it up? thanks
slideways...
03-01-2006, 11:44 AM
huh?
look at a better diagram. you can tie it in with any extra wires, or just get a MAF connector from somewhere else.
just plug the other pressure line. you only need the one to the rack and the return line.
huh?
David_NISMO
03-01-2006, 11:56 AM
So do you have the sr20 MAF and not the plug? If I had some pictures I could help you out.
