2001 GA-SE Headlamp Bulb
crys36
02-22-2006, 03:25 PM
I have to replace the Pass front Hi/Low lamp in my girls GA. From what I read or think I read the whole headlamp assembly comes out and then U replace the bulb ? Or can it be done from behind like in older vehicles. I don't want to break anything so if it comes out how should I go about it--Thanx in advance--Crys36:2cents:
GTP Dad
02-22-2006, 05:52 PM
Check the owners manual for directions. The assembly is held in by two sliding metal clamps. Pull out and up and the assembly should come loose. You can then replace the lamp but you can't replace it from behind like the older ones.
