revving to high
88B18aHB
06-26-2002, 10:36 PM
running real high at idle 12-1700 rpm b18a motor
replaced air filter sprayed intake with thottle body cleaner no help seems to be no prolbrem with vaccum line's when the car isn't idleing runs ok i was thinking idle air control value damn dealer parts any idea's :bloated:
ci5ic
06-26-2002, 10:56 PM
What about the throttle cable? Have you tried adjusting that?
88B18aHB
06-27-2002, 12:21 AM
doesnt seem like the thottle is sticking just a high idle
ich_folge
06-27-2002, 12:57 AM
Adjusting the throttle cable has nothing to do with the throttle sticking
(1) Does your engine go up and down at idle?
(2) Does it do it all the time or just at warm up or only after the car is warm
If the idle is steady then its probably your throttle cable needing adjusting it idle goes up and down then its problem a vacuum leak and if it only does it after the car is warm then its probably the fast idle valve
88B18aHB
06-27-2002, 01:02 AM
the idle is steady high like 1500 rpm wont drop much or raise to much
how would i adjust thottle cable ?
ich_folge
06-27-2002, 02:25 AM
Look at the throttle body where the cable connects to it the are 2 bolts holding the cable on 8MM (if I remember right) one holds the cable in place one adjusts the cable (adjust the one on the right) do it with the car on so you can judge your idle when doing it
crxlvr
06-27-2002, 07:40 PM
yeah sounds like ur throttle is just open too much.
88B18aHB
06-28-2002, 12:33 AM
thanks but didnt help at all when i tighten the bolt it just puts tension on the thottle cable an make the car rev higher but when i losen it nothing happens
ich_folge
06-28-2002, 12:57 AM
Hmm that’s odd well your problem it there someplace in the cable it may be binding up someplace
88B18aHB
06-28-2002, 01:05 AM
not sure i hate to take it to a shop cause it being a b18a in a civic they dont know whats what mechanic out here are shitty still think it might be the idle air control value :bloated:
ich_folge
06-28-2002, 02:49 AM
It may be the fast idle valve staying open after the car is warm. Oh BTW win you adjusted the cable did you do it when the car was warm?
Setanta
06-28-2002, 04:14 AM
ICV needs replacing. My SiR currently idles at 1500-1800 rpm and I just have to find a replacement - you won't have as bad luck finding one I think :)
88B18aHB
06-28-2002, 12:14 PM
icv ? idle control value is that it cause thats what guys at work say but they said that the dont really go up like that maybe i could just clean it but in the chiltons it say be careful not to damage so im leaving it alone how much is this going to run me an is it going to damage anything the way it is now havent noticed any difference in the way the car runs just burning more gas
ich_folge
06-28-2002, 01:45 PM
Ya you may not need to replace it just try to clean it first
Take off your intake have someone in your car start it and punch up the RPM to about 3000 RPM and hold it there. Then spray some carb cleaner into the TB only a little (your engine will bog a bit) repeat a few times. Turn off car et car cool off then restart car and see if it still does it if it does try to clean it again if this does now work replace it
shatshadarach
07-02-2002, 12:59 PM
i noticed you said when you adjusted your throttle cable you said you tightened it...dont...loosen it, that section thats just bare cable between that adjusting bracket and the throttle body, you should have about 3/8 to 1/2" play in it...the idle should be set with the idle adjustment screw on the bottom of the throttle body...that screw is set from the factory, so do not touch it...
