Power
Zaina05
02-19-2006, 07:23 PM
Just a quick inquire , just got a afe cold air intake and a super chip, is this goning to make a huge difference to my 2005 mustang gt? if so how huge
neatofrito1618
02-19-2006, 08:28 PM
xcal2's work good for 05 mustangs. a CAI will make a little difference but not much
Mustang0524
02-20-2006, 03:47 PM
Do they have these chips for v6's ?
96'
96'
neatofrito1618
02-20-2006, 03:53 PM
Mustang0524
02-20-2006, 05:39 PM
Some of these chips add power? Curious cause i have about 600 bills to sped atm looking for a quick up in hp on my v6.
neatofrito1618
02-20-2006, 05:52 PM
yeah i have on one my v6, it works good.
6speed
02-23-2006, 10:09 AM
not a huge amount; probably not as much as you wouldve liked for the $ you probably spent, i wouldve substituted a timing adjustor for the chip; since theres really no tuning needed when your car has no major modifications
AltecZX2
02-23-2006, 01:23 PM
I'm picking up an Xcal2 fro my escort this week. I love being able to fix that shit tunes ford give stock.
neatofrito1618
02-23-2006, 02:19 PM
yeah i cant stand fords slow ass stock shifts. they also recalobrate your speedo when you get gears and all the other stuff. there really good for cars with nitrous
6speed
02-23-2006, 02:51 PM
i guess since ive never owned an auto i dont know the advantages of having a chip to firm up shifts. but for the other things, why would the high cost of a chip be worthwhile; its not like its going to give you very much power. all the chip is going to do for power increase is advance your timing a little; why not just go with a steeda timing adjustor? what would be advantages of running a xcal for a nitrous setup?
neatofrito1618
02-23-2006, 03:35 PM
you can make it run richer, program the computer to mods, and the best part is changing the shift points for auto's and making it shift harder. its good for nitrous because you can tune it for a 75 shot,100 shot,ect. inside your car
Mustang0524
02-23-2006, 05:32 PM
If i were to get this chip, i dont know jack about how to calibrate anything on the computer, could i get this chip, have it installed and tuned by a shop or something? Or would it really be that hard to learn, im pretty mechanically inclined.
neatofrito1618
02-23-2006, 07:21 PM
If i were to get this chip, i dont know jack about how to calibrate anything on the computer, could i get this chip, have it installed and tuned by a shop or something? Or would it really be that hard to learn, im pretty mechanically inclined. when you buy the chip the person that tunes it for you gives you 3 coustom tunes. and it comes with a little computer cd that allows you too tune a few things like gear ratio's and timing.
6speed
02-24-2006, 08:13 AM
never worked on a v6 either so like i was saying maybe its all different but on a GT for a perfectly fine nitrous install you would need a timing adjustor to retard the timing, colder plugs are preferred, a fuel pump, a window switch, and a purge. the higher you jet it the more timing you remove.
ClioRacer_72
02-24-2006, 08:21 AM
I recommend www.turbonator.com (http://www.turbonator.com) .. they supply these cold air swirlers that can give yur high performance car a 35% hp boost :D
Mustang0524
02-24-2006, 09:20 AM
Turbonater eh? Sounds kinda cheesy to me..... Does it really work?
ClioRacer_72
02-24-2006, 09:23 AM
If you check out the site it explains the theory.... they have had lots of feedback from ppl who have big power american cars and they have noticed a sudden change in performance... i dunno im getting one for my clio... but im gullible... it seems like a valid theory of spining the air... dunno its up to u wat u think.. im gunna get one... if it improves my mpg il be happy :D
SkylineUSA
02-24-2006, 11:37 AM
I am callin BS.
By the time the air hits the runners, the air will have smoothed out by then. Plus, you can get an increase in milage and HP by a cooler intake charge(colder outside temp). Blanket statements are just that! Might I add, the unit is installed before you TB, what do you think the butterfly valve is going to do to any vortex? Its not like the gas is getting mix any where near where this thing is installed.
neatofrito1618
02-24-2006, 12:37 PM
never worked on a v6 either so like i was saying maybe its all different but on a GT for a perfectly fine nitrous install you would need a timing adjustor to retard the timing, colder plugs are preferred, a fuel pump, a window switch, and a purge. the higher you jet it the more timing you remove. yeah its the same on a v6, i normaly drive around on a performance tune and when i spray a 75 shot i go to stock timing and when i spray 100 i retard it 2*
TheStang00
02-24-2006, 01:16 PM
dont buy a turbonator, save your money. talk about a hoax
