2001 Grand Caravan 3.3
cbillings
02-16-2006, 07:31 PM
How much of a job is it to locate & replace thermostat?
Vats
02-17-2006, 08:36 AM
Its not too bad, onthe 3.8L it is located on the left side of the engine on he top near the intake plantum, and I think the 3.3 and 3.8 are the same block. The haynes manual will guide you through.
Is he vehicle overheaing?
cbillings
02-17-2006, 06:24 PM
No it wasn't overheating, it just would not blow any hot air. I did replace t-stat, it took all of 20 min. I wish all repairs were that easy. Thanks for the input.
74lemans
02-19-2006, 09:12 AM
Our van will warm up to correct temp (and blow hot air from heater)when idling, but once we start moving, the temp gauge goes back to C and the heater blows cold. Would this be the thermostat?
cbillings
02-19-2006, 11:02 AM
It could be, I'm by no means an expert but it sounds like a t-stat problem. One thing about it it's a very easy process to change out. Drain water to below top hose, remove the 2 bolts holding t-stat housing cover, (1/2 bolts located upper left side of engine, follow upper radiator hose), replace t-stat, remember the direction old one was placed, reinstall housing and re-fill fluid. Let run for a while with cap off to bleed any air out of system, squeeze upper hose to "burp" a couple of times. When no more bubble show up system should be bled. Hope this helps.
