shallow/deep clutch
bl1tzk1213g
02-14-2006, 12:54 AM
Hmm... somtimes my clutch feels a little shallow than normal. I believe when i turn of the engine its normal, then while driving, sometimes it kinda gets shallow, weird. any ideas?
xavier3jr
02-14-2006, 03:23 AM
Have u checked the break fluid?
gthompson97
02-14-2006, 10:31 AM
It's actually a clutch fluid resirvoir, but it does use brake fluid.
And have you checked it lately?
DragonofBC
02-14-2006, 10:43 AM
Rub your hand down in the carpet where the clutch is and up around the assembly. Is there any liquid?
gthompson97
02-14-2006, 11:43 AM
That would eventually lead to a loss of all fluid and then there wouldn't be anything at the pedal. I don't think this would have anything to do with it, but it never hurts to double check, being as it takes 2 seconds.
bl1tzk1213g
02-14-2006, 05:35 PM
I dont see any on the carpet since i've adjust my clutch a few times. My reservior is not empty. I've been having a leak and im not sure where its coming from, could they be related? It seems like its coming from the trans axle. Maybe some bad seal?
xavier3jr
02-14-2006, 06:22 PM
Your axles have nothing to do with your clutch....check your brake lines ruining from your slave cylinder to the clutch fluid resivoir. see if there all tight make sure there not leaking. And if you have had a leak have u been bleeding the clutch by any chance? If not there could be air pockets in your lines and that would defiantly cause it to happen.
defiancy
02-15-2006, 01:51 PM
yeah I had the same problem. I bled the clutch and put in new fluid and it was fine.
