95jgc l
cggreen47274
02-13-2006, 08:58 PM
someone tell me what i did wrong i changed the lifters the timimng chain head gasket now it wont start if i crank over and over and hold the pedal to the floor it my start then when i release the pedal it dies did i forget something??????????????
dksob81
02-14-2006, 07:15 AM
It sounds like the IAC Valve mightnot be working. The IAC Valve opens to allow air past the throttle plates into the engine, to allow the engine to idle.
Adjust the pintle on the IAC Valve, to do this, with the battery disconnected it removed from the Throttle Body, push in a hold the spring loaded sleeve, then turn the pintl/tip of the valve clockwise to move it in about an 1/8", then put it back in the TB, connect the electrical connector and reconnect the battery.
cggreen47274
02-14-2006, 06:14 PM
i done that it starts now but when it warms up it quits running also the exaughst header is getting red hot
dksob81
02-14-2006, 06:58 PM
Your timing is off, set the #1 Cylinder at TDC on the compression stroke and check the timing marks on the Crank and Cam Shafts.
BenBB
02-15-2006, 08:58 AM
Yea but if you set the timing and it still dosent work, could it be the Camshaft Posision sensor because doesn't that correlate with the crankshaft sensor to set the timming on the other pistons.
dksob81
02-15-2006, 04:30 PM
The Crank and Cam Sensors corrolate to adjust the timing between the Fuel Injectors and Ignition Coil (Spark), not actual engine timing.
cggreen47274
03-03-2006, 07:18 PM
ok guys i did everything you said and it runs great you guys are the best thanks for all the help
dksob81
03-04-2006, 05:45 AM
What was the actual fix?
cggreen47274
03-05-2006, 10:22 AM
the timing was off by 180 degrees plus the map sencer was toast
cggreen47274
03-06-2006, 09:11 AM
timing was off 180
