angel eye ?
95civicman
06-23-2002, 12:03 PM
on the passenger side ring around the low beam it dosen't light up? all the other ones do but this one dosen't. do any of you know what i can do or what is wrong? it's not that little fuse thing on the wire because i cut that off and just ran a straight wire to the battery just to test it. i'm pretty good with electronic shit and lighting with my car so just tell me a way to fix and i'll try? thanks
crxlvr
06-23-2002, 02:24 PM
the lil light that lights it is prolly burnt out.
Civ_Jimbo
06-26-2002, 01:49 AM
Make sure the right is grounded, and getting power.
95civicman
06-26-2002, 09:15 AM
oh it's grounded alright, i made sure of that. i think i'm just goin to have to open it up and check out the bulbs:bloated: :mad:
wagsaccordsir
06-29-2002, 01:06 AM
If your good at electronic shit, I wouldnt think you would be here asking ??? As if a light doesnt work, its obvious that it comes down to electronic theory!!! Whether its A, B, or A1/2 its traceability... Maybe you should check the flux capacitor, or the wire grease!!!
colechaney
07-02-2002, 10:55 PM
Uhhhh only Mustang's have flux capacators, and wire grease is only available in Germany and Switzerland..... you ducking fumass:rolleyes:
crxlvr
07-03-2002, 07:16 PM
only deloreans that travel back in time have flux capacitors!!
colechaney
07-03-2002, 11:02 PM
My bad
j.fuggi
07-05-2002, 12:54 PM
ok well you really arn't supposed to cut that wire. there is a reason for it. most likely its a resistor of some sort and by cutting it (as said specifically not to) you must have messed something up. or maybe just really lowered the life span of that bulb.
95civicman
07-06-2002, 02:25 PM
well it wasn't workin before i cut it tho.
