V6 Speed Chips
Vic_45
02-07-2006, 09:11 PM
Looking for info on the multitude of speed chips for the 2005 4.0L V6. I see them everywhere and there are many different types, from simple resistors to extensive rewire jobs. All boast the same thing more HP and more MPG. I am very interested in the more MPG's. Do these things work? If so, will they damage the engine?
neatofrito1618
02-07-2006, 09:35 PM
SCT xcal2's and diablo predator are both good chips but xcal2's will yeild more hp and can remove governets/limiters and make auto's shift faster/harder. $20 ebay chips can damage your engine because the trick the computer into thinking the air coming through the intakes is colder then it acually is. and yes they do work, i have a xcal2 on my 02 and its the best mod i have done
AltecZX2
02-07-2006, 09:55 PM
those resistors wont damage your motor, you wil have a nice power gain for aobout 10min..then teh PCM will learn you tricking it and correct itself.
the Escort guys have been using those resistors on a on/off switch for years...no one has hurt a motor (in over 8yrs).
Dyno showed a 5.4 hp/7.7 tq differnce at peak....and a max gain of 14.4 hp / 10.8 tq. at 6500 rpm at points in the powerband.
how ever you can build a resistor setup for $7
