95 Grand Am GT
lionelkirk2004
02-06-2006, 05:00 PM
When I start to back up or even when I just start driving, I hear a clonking noise on the right side where the tire is especially when turning, then the ABS light comes on. Any Idea what it could be?
GTP Dad
02-06-2006, 06:25 PM
Bad wheel bearing probably due to a bad CV joint. Have the axle shaft checked but the bearing will need to be replaced. The bearing and the ABS sensor are a single unit and will have to be replaced as an assembly. Not hard to replace but they are expensive.
lionelkirk2004
02-08-2006, 09:25 AM
I was told that it was the Tie Rod??
GTP Dad
02-08-2006, 01:42 PM
If the ABS light is on then it has nothing to do with a tie rod unless it broke the wire to the sensor but then you wouldn't be able to drive the car. I don't know who told you it was a tie rod there is no way a tie rod would cause the ABS to come on.
