AIR DRIED BEEF DOG FOOD
96 Supreme 3.1L coolant leak
tawally
02-04-2006, 08:18 PM
Have a 96 Cutlass Supreme w/the 3.1L V6. Has a slight coolant leak. Coolant is lying in the valley under the intake manifold. Thermostat housing is dry. Coolant is starting to drip down in front of the starter. Any help would be appreciated. Thanks for your time.
andercee
02-05-2006, 02:36 AM
first of all check all the hoses and clamps.... your radiator cap might have junk in it or something and may be spraying out..
what i'm trying to say is find the leak...
good luck
GTP Dad
02-05-2006, 11:12 AM
It is possible that you have a leak in the intake manifold gasket. Check your oil to see if it has any water. It will look chocolate in color rather than tan and you may see an increase in the oil level. If that is the case get the manifold gasket replaced asap and don't drive it this will ruin the bearings. The other possibility is that you have a leak in a hose that only shows up under pressure. You can have the cooling system pressure tested as that may show you where the leak is. Good Luck!
ALANGARCH
02-06-2006, 03:43 PM
First Thing Id No Is Get Some Alumaseal
And See If It Stops
If Not Could Be The Intake Manifold Gasket
