Peugeot 206 cc
tannee
06-21-2002, 01:26 AM
hey guys...considering this car instead of the rex...
what ya guys think?
any input...specs etc?
thanks!
Spunkymonkey
06-21-2002, 01:37 AM
Here are the specs for the 2 litre convertible
Weight: 1152kg
Engine Code : EW10J4
Engine Location : Front
Engine Orientation : Transverse
Engine Description :
Four cylinders, in-line, belt driven DOHC, four valves per cylinder, all alloy.
Capacity (Cm3) : 1997cm3
Fuel System Type : PFI
Maximum Power : 100kW @ 6000rpm
Maximum Torque : 190Nm @ 4000rpm
Cylinders : 4cyl
Valve Train : DOHC
Valves Per Cylinder : 4v
Block Material : Aluminium alloy
Head Material : Aluminium alloy
Compression Ratio : 10.8:1
Fuel Type : 95 RON PULP
Fuel Tank Capacity : 50 litres
City : 8.0
Highway : 5.3
Max speed = 204km
0 - 100 in 9.3 seconds
Turning circle 10.5 m - which is pretty huge for a smallish car.
Suspension/Front Description :
Independent, MacPherson struts, cast-iron lower I-arm, coil springs, gas dampers, jointed mount 20mm anti-roll bar.
Suspension/Rear Description :
Independent, cast-iron trailing arms, torsion bar springs, angled gas dampers, fixed mount 19mm anti-roll bar.
Spunkymonkey
06-21-2002, 01:41 AM
There is also the 1.6
Maximum Power : 80kW @ 5800rpm
Maximum Torque : 147Nm @ 4000rpm
Max Speed = 188km
0 - 100 in 12.5 seconds
Umm....this one seems pretty sluggish to me :p
tannee
You reckon they are worth it?? :confused:
ive heard bad things about the maintainence and reliance of the 206...
but on the track...they look mighty fine!
Spunkymonkey
06-21-2002, 01:48 AM
There 2 litre version is only in manual transmission....
There is big difference in performance compared to WRX.
The specs mean, even the 2 litre model will have less power than Pete's civic and my sisters VTIR civic which have max power 118kw.
The WRX comes with about 155 - 160kw max power for the normal version, and over 200KW for the STI.
You have to think about whether this car is to get you from a to b, or whether its going to be like a project car or something...and where to park it....etc.
Spunkymonkey
06-21-2002, 01:51 AM
Not for the performance you get for the price.
Its a European car, thats why its expensive. Even if I wanted to go european and something more luxurious, I would prefer an Audi.
From the car research site, it has them about 35 - 40K
for that much money, I'd buy a ITR or S15
B16a4me
06-21-2002, 12:38 PM
Peugeot 206cc .......... I thought it was a big scooter
100kw + 1152kg = SSSSSSSLLLLLLLLLLOOOOOOOWWWWWWWWW
IMHO HTH FWIW
slave
06-23-2002, 10:01 PM
Yes Peugeots are slow, but my mum has a 306 and Ive driven the 306 GTi6 and fuck me do they handle for a front wheel drive, yummmm. But they handle best once you get em sliding a bit.
TOYVTi
06-25-2002, 11:26 PM
Hay Tannee, I thought I told u, get a Mitsubishi, VR-4 1998 model, look, I'll sell u mine!!!!!!!!!
Its still for sale, and it moes down WRX's easy, it can beat a Version Six off the line, and I'm talking about the ST EEEEEEEYYYYYEEEEEEEEEE!!!!!!!!
So basically, its was a good race, was mi mates sti, and his car is stock apart from rims, and other non go fast bits apart from new filter, so mi big taxi was doing well to keep up even i say, but yeah it was looming up to make the pass. I tell ya, my whale has the go eh!! hehehe
Tannee, just buy mi car, ok ill do a deal for ya!!!!!!! U just let me know! hehe
Spunkymonkey
06-25-2002, 11:33 PM
he's got to learn how to drive manual first :silly2:
Setanta
06-26-2002, 02:42 AM
The 306 at the dyno day made 10KW at the front wheels more than I did. I just watched the dyno video of it.
This means that it's putting out the same power as Chuck, Adrian and kit did with their modified B16A's. Chuck - didn't he say it was stock?
Something is really wrong with these figures - if the 306 is making 100KW at the flywheel as Q posted, then there is no way it is getting 90.4 at the wheels - P/S, alternator and A/C would suck most of that 10KW straight away.
This is weird - I swear Croydon's figures are off
:bloated:
B16a4me
06-26-2002, 02:58 AM
Different motor pete. One of the pugs had that motor and made crappy power (similar to yours :D ) The one that made similar to mine ( actually lower :D ) is listed as 120Kw at the motor or 175hp.
Setanta
06-26-2002, 03:06 AM
bastard :p
I still think they borked my dyno run though :D
I keep adding the figures up and it all comes out wrong.
Ah well - I didn't know that there were two pugs running that day - only saw one :)
B16a4me
06-26-2002, 03:16 AM
FWIW I think the Croydon dyno reads higher than others
Setanta
06-26-2002, 04:21 AM
I keep looking at my graph:
http://home.iprimus.com.au/cuchulainn/civic/dyno_graph.jpg
Assume they did the run in 4th gear. 3rd peaks at 8000rpm at 140 as I recollect (same as the 'tegs). So it has to be 4th. Now I've peaked the rev limiter in 4th at 180km/h as I recollect - (Chuck/Moppie, can you confirm 4th gear run out?).
Ok, on their graph it peaks at 160km/h which to me indicates that they may not have been pushing it all the way to 7300 which is peak power as I recollect. If so, maybe that's where my missing numbers are.
Chuck - dyno operators can tweak a dyno to read whatever they want - remember what the VW first did? ;p I've heard that quite often figures can be messed with based on how the car is ramped up too.
Spunkymonkey
06-26-2002, 04:43 AM
I wouldn't be suprised if their dyno does read a bit higher than it should :p
B16a4me
06-26-2002, 09:51 AM
Ok........Runs were in 4th as I was tagging the limiter at the creek and that was 92 mph. On my car 1000 revs = 20 km/h. On the Dyno day mine was cutting out at 144 km/h (7200) which is spot on for limp mode. Mine is geared shorter (lower) than yours, I'm guessing.
At 140 km/h your making about 67kw and mine was making 89Kw???
When I fixed the fault and reran it on the dyno, it was the same profile map but continued to 165 km/h.
Don't like your dropoff prior to VTEC????Yuk!!!! Everyone is telling me I've got VTEC coming in to early but my graph is perfectly linear.
Your graph proves your VTEC is working but you've got something wrong with that low a power figure????? Have you ever checked your compression.......... Blocked cat........... something is WRONG!!!!!!!!!
Your profile indicates they went all the way through the rev range (even down to the 10 - 15% dropoff) but it's just way too low.............
Setanta
06-26-2002, 10:39 AM
Compression is fine when I had it tested just after I got the car (12 months ago). There's a good chance the cat/o2 sensors may be choked - not to mention I have a gut feeling that my high idle is a cold setting that runs the fuel rich - until I find a working ICV I won't know. I wish I'd got them to put a sensor up the tailpipe just to check the A/F ratio.
Only other thing is that I had to modify the new dizzy cap to seat it properly - I might get the ignition timing checked just in case it's running retarded as a result of that.
B16a4me
06-26-2002, 11:27 AM
Retarded timing isn't enough. I retarded mine on the dyno as far as the bolt would let me go and only dropped 2 kws
How do your plugs look after a hard run. At the creek I was pulling the plugs after every run (old habits die hard)
slave
06-26-2002, 04:42 PM
In terms of 306 engines, they have one hot engien running trhough three cars, its used in the now defunct 306 GTi6 the new 206 GTi, and the bigger 406. Slightly modded in the GTi6 as it puts more power out in that guise than it does in the 206. Just a few different bits in it etc.
Setanta
06-26-2002, 04:45 PM
Plugs have a very light colouring to them - light yellowish-grey.
They are that colour when I change them every 15000km - minimal wear.
That dead spot before VTEC that you mentioned Chuck - that's where the 'tegs pull away from me as I can't get on VTEC fast enough (also where Lang's VTiR hauls me in until I get on the band again).
tannee
06-28-2002, 09:28 PM
talk about going off topic! :p
Ssom
06-29-2002, 12:30 AM
Well while the 2O6CC 2.0 manual is a good car, I say, go with a 3O6 GTi-6 for less cash and more rewards, hell I they even give Civic SiR's a bloody hell of a run for thier money and completley out-handles them :D :D
Setanta
06-29-2002, 09:52 AM
uh-huh
Want to confirm this moppie? ;)
Sorry, fat, ugly and slow - the only way to describe the pugs :D
B16a4me
06-29-2002, 09:59 AM
I LUV 205gti's. I used to travel the old road in my RS2000 and the only time I couldn't keep up with a car on that road was some refugee-from-a-racetrack 205gti. We stopped at the cafe and the thing was lush(do they still use that word)
Setanta
06-29-2002, 10:04 AM
I don't think they do.
Gut instinct is that instead of "lush", you need to insert "like", y'know" and some other words that make no sense so that no-one understands :p
Isn;t a "lush" an alcoholic? :p
205s were nice - but not in stock trim.
Spunkymonkey
06-29-2002, 04:28 PM
LOL
actually chucky...I'm sure you'd be suprised to realise...a lot of girls still use the word "lush" :p to describe...cute guys LOL
"He's so lush" LOL
or do the Don Burke "This bush is lush" :p
perhaps you should use the word immaculate or something :silly2:
