wiper control module location for 96 grand cherokee
Nissin93
02-03-2006, 08:21 PM
I need help finding the intermitent control module everyone said that its in the left kick plate on the drivers side but its not there and my wipers work on intermediate sometime I need help in a big :banghead: :banghead: :banghead:
nick0750
02-04-2006, 08:06 AM
your vehicle does not have a delay module delay is controlled by the bcm which is under left side of dash, however you do have a relay for the delay in the power distribution box.
BODY CONTROL MODULE
A Body Control Module (BCM) is used on this model to control and integrate many of the vehicle's electrical functions and features. The BCM contains a central processing unit and interfaces with other modules in the vehicle on the Chrysler Collision Detection (CCD) data bus network.
Some of the functions and features that the BCM supports and controls are the speed sensitive intermittent wipe, pulse wipe, and wipe-after-wash modes. The BCM is programmed to energize the intermittent wipe relay in response to certain inputs from the multi-function switch and the wiper motor park switch. For the speed sensitive intermittent wipe feature, the BCM also uses an input from the vehicle speed sensor, which is received on the CCD data bus from the Powertrain Control Module (PCM)
The BCM is mounted under the left end of the instrument panel, behind the instrument panel support armature and below the left switch pod. Refer to Instrument Panel Systems for removal and installation procedures. For diagnosis of the BCM or the CCD data bus, refer to the proper Body Diagnostic Procedures Manual. The BCM can only be serviced by an authorized repair station. Refer to the Warranty Policies and Procedures Manual for a listing of authorized repair stations.
BODY CONTROL MODULE
