Fan/Heater Won't Shut Off(95 Chevy 1500)
userpete1037
02-02-2006, 01:03 AM
My heater is stuck on the next to Hi setting. When i cut it to the off position it's still running. The climate control and vent settings work fine. Unless i pull the fuse, it will run. Oh, my truck was off for over an hour. I started it up and the fan wasn't running and it wouldn't cut on either. 10 sec later, it started running again on its own and won't cut off.
userpete1037
02-02-2006, 02:57 PM
Well, i did some experimenting on my own and i replaced the resistor pack for the heater and that didn't fix the problem..can u believe that!!!! i was sure that was the problem. The only other thing i can think of is the control is going bad because now it's popping on and off randomly by itself.
777stickman
02-02-2006, 07:31 PM
So Pete, tell me what fuse your pulling to stop the behavior. I'll be looking at a '98 manual but hopefully it will be close. Also need to know if your sure of the fan speed when it kicks on?............Steve
dchevyman
02-03-2006, 07:46 AM
check your heater fan relay under the hood....???
userpete1037
02-03-2006, 10:24 PM
I've been pulling the heater/ac fuse which is in a compartment on the driver's side. I found out something interesting today. I pulled out the heater/ac control unit and disconnected the switch. I checked the leads on the switch and they are corroded very bad. I checked with the parts store and they have it for about $8. So what i'm going to do is try the switch before going to a scrap yard and getting the whole hearter/ac control unit which i priced at $50...dealer wants $163...hell nooooooo. I think the switch is going to fix it though. i'll post results.
777stickman
02-04-2006, 09:40 AM
Hey Pete: Looks like you're going in the right direction. Power goes thru that fuse to the Heater/AC control unit. Good luck..........Steve
userpete1037
02-05-2006, 12:19 AM
Well my hunch was right. My job has an old 95 chevy with the same control unit. I popped the switch out and installed it in my truck and it works perfect. No continuous running of the heater/fan. As for the infamous resistor pack i installed, at least i won't need one in the future because it's brand new.
