Question about CPI hose routing...
georgelovesdirt
02-01-2006, 03:06 PM
I noticed in some pictures in this sites FAQ's that on the passenger side sometimes the hoses are crossed for the back 2 holes, and some aren’t. Which is correct? I have a 95.
Also, I hear water sloshing sounds behind my dash when I drive, what is this noise?
Gabe25
02-01-2006, 04:46 PM
It doesn't matter both are correct. The fuel distribution is all the same. That sloshing sound you hear is mite be coming from your heater core. Click on this. Mite help you. http://www.automotiveforums.com/vbulletin/showthread.php?t=469926
georgelovesdirt
02-02-2006, 11:09 PM
in http://www.automotiveforums.com/vbulletin/showthread.php?t=473110&highlight=4.3+CPI it says it does matter, but says they should go front to back matching the cylinders, unlike the way it come stock, does it realy not matter?
Gabe25
02-03-2006, 10:45 AM
The way I look at it. I just place it so that the lines don't get kinks and the least amounts of bending. Like I said earlier. It doesn't matter which line goes where. Your C.M.U. sends a pulse to the fuel regulator which disburst the fuel evenly.
rlith
02-03-2006, 03:18 PM
the 92-95 CPI does not require the hoses in a particular order as it is batch fired. Only the 96+ CSFI system requires a specific order as it is sequentially fired.
