LS crower 403s
iVteC_PoWeR
01-31-2006, 09:13 PM
i know people recommend these and they say it requires the springs/retainers but would I still need them if I wasnt going to rev any higher than the stock redline?
TurboGSR96
01-31-2006, 10:37 PM
i'm assuming those are cams and if that is the case look on crowers website and it will tell you if they are compatible with oem valvetrain.
iVteC_PoWeR
02-01-2006, 05:48 PM
oo yea i already checked that it says it requires the springs/retainers but i was just wondering if it was for the stock rev limit or higher revving...cause the springs/retainers are kinda expensive
TurboGSR96
02-01-2006, 06:03 PM
the cam will be ok for a very high rpm or stock rev limit, I run my stock GSR cams to 9k without a problem, its the stock springs/retainers/locks etc. that can't keep up with the extra rpm. Actually crower has pretty reasonable priced springs/valve/retainers compared to what I paid for my stuff.
iVteC_PoWeR
02-01-2006, 07:23 PM
so would it be ok to put in those stage 2 cams without any valvetrain upgrade and not rev any higher than i would if my car was stock?
TurboGSR96
02-01-2006, 08:49 PM
I'm gonna say no because even though you are not going past the factory rev-limit, it specifically says that the spring/retainers are required. Remember you also have to buy valves in most cases and valve locks, valve seals, seat locators and sometimes guides. it add's up.
