quick question ???
maistro0
01-31-2006, 10:18 AM
Im New Here But I Wanna Say Thanks Cause This Site Has Help Me A Bunch But Ive Got A 1998 Gtp High High Mileage 200k 3800 Supercharged Motor. One Problem Is The Rattling Coming Out Of My Sc Ive Been Reading Here And Apperantly Is The Coupler But Deose That Affect Performance In Mt Gtp???? Im Going To Change It Anyways But I Was Just Wondering If It Affected And Also My Trac Off Light Is On And I Cant Get It To Go Off Any Sugestion ?? Thanks
maistro0
01-31-2006, 10:27 AM
I Was Just Reading The Previuse Thread And I Guess Having The Trac Off Is A Good Thing Right?? But I Still Wanna Know Why I Cant Turn It On And Off With My Button Thanks.
ern2112
01-31-2006, 10:30 AM
Cant help on the SC so much..(I have a 98 as well...but not the SC)..but I would assume if you have rattling.....it is out of true...and that would send vibrations...therefore tearing up other parts....I think you getting it fixed is smart.
The ABS light coming on? I bet you have an ABS issue...the traction control ties directly to the ABS.
ern2112
01-31-2006, 10:32 AM
I dont really agree that Trac off is a good thing. Point and case.....I hit a puddle one day inthe middle of the highway......while in cruise control.....the trac light comes on.....and the cruise shuts off...and the car corrected it's self.
For cruising around.....I think it is great..it really WORKS..for a little race off the light...reach over and turn it off
BNaylor
01-31-2006, 10:36 AM
The rattling sound is the coupler so replacement should take care of it. But with that mileage while the snout is off you might consider new snout bearings and seal.
I do not believe the supercharger and traction control problems are related.
maistro0
01-31-2006, 10:40 AM
Actually I Do Have The Abs Light On
maistro0
01-31-2006, 10:46 AM
what do you think about the products from zzperformance are they good if so ill buy the coupler and anout bearings from there
but the coupler being bad deos it take power away from the sc??
ern2112
01-31-2006, 10:59 AM
Bob could better answer this...but based on what I have seen....they are outstaning. Everyone seems to like them.
Your abs system is in trouble...thats why the lights on the trac control or lit...and the ABS light is lit. My light has came on before....but, when I turn off the car....it will go away and stay away. Not sure why it happens...but someone will chime up and tell you.
BNaylor
01-31-2006, 11:08 AM
Ernie is doing great on your ABS/Trac problem.
On the SC - Going through ZZP is the best way. They normally have all parts in stock. Plus the coupler is the improved one. Depending on how bad the coupler is worn it will affect supercharger performance. Are you losing boost?
maistro0
01-31-2006, 11:24 AM
no im sure if im loosing boost i dont have a STOCK boost gauge dont know why ---how can i install a boost gauge????
BNaylor
01-31-2006, 11:39 AM
Most of us get aftermarket boost guages to accurately reflect SC boost. Companies like AutoMeter, etc. Easy to install. The meter will obtain the boost reading off of engine vaccum and ties into the MAP sensor vacuum lines.
Checkout PFYC.COM and 3800Performance.COM for various gauges.
How does your engine feel when you accelerate hard or go WOT?
richtazz
01-31-2006, 11:48 AM
ABS/Trac off light staying on is most likely a bad hub. It will require an ABS capable scanner to pinpoint which wheel is the problem. The wheel speed sensors are part of the hub bearing, so if it's not a wiring issue, you'll have to replace a hub bearing.
