99 Voyager 3.3 Can I get codes on this?
mimzie
01-30-2006, 04:28 PM
Does anyone know how to get codes on the 99 Plymouth voyager? The ignition thing does not work, Can I jump A and B connectors to get the code? Which ones are A and B though? I cant find the right diagram for this, is it GM? Dodge? what?
Rachel
Rachel
mimzie
01-30-2006, 04:57 PM
Nevermind, I think I found it, going to try, here's how
Dan Stewart wrote about the 1999+ Voyager/Caravan with digital gear selection display:
There are 2 functions that can be accomplished with the key-on sequence. Get Diagnostic Trouble Codes by placing the key into the ignition. Push and hold the both the "Trip" and the "Reset" buttons with the left hand and turn the key to the "ACC" position (first position between "LOCK" and "RUN"). Continue to hold both buttons in and count to 5. Release both buttons, display should read trip mileage instead of total mileage. Push the "TRIP" button and the odometer will display DTC'S in rotating sequence instead of displaying total mileage.
The second function is an instrumentation diagnostic. Place key into ignition, press and hold both "TRIP" and "RESET" while turning the key to the "RUN" position. Continue to hold both buttons in until odometer displays "CODE". Release buttons. The display will then display "999". Afterward it will display "CHECK 0" and test the analog gauges. It will then display "CHECK 1" and test the digital displays.
moparfanatek
02-20-2006, 02:33 PM
go to www.autozone.com/servlet/UiBr...O.jsp#hd1-1--1
:banghead:
:banghead:
