brake fluid and clear parts.
20V_AE82
01-28-2006, 05:15 PM
Hi all. I have a R34 GTR which i built a few years back but im not very happy with the paint job. (i didnt spray the body. tried to paint it by hand) If i leave it to soak in brake fluid will it damage the clear parts that have already been fitted? (eg windscreen ect)
freakray
01-28-2006, 05:38 PM
Previous threads about the subject have warned to be careful with the clear parts.
You could always remove the clear parts before stripping the paint.
20V_AE82
01-28-2006, 06:14 PM
im a bit worried about braking the window part if i try to remove it.
freakray
01-28-2006, 06:20 PM
What kind of glue did you use to put it in?
20V_AE82
01-28-2006, 07:21 PM
just normal hobby glue. Tamyia brand
MPWR
01-28-2006, 09:07 PM
Forget the brake fluid.
Why do people still think this is a good way of stripping paint from plastic? Yes, it will remove paint- but it's not plastic safe. You may get lucky, or you may get a nasty surprise. Why risk it?
Use automotive degreaser (Castrol Super Clean, Purple Power, Simple Green), or 99% isopropyl alcohol. Safe, cheap (especially the alcohol), effective, and likely won't take years off your life.
Your choice.
20V_AE82
01-28-2006, 09:43 PM
i have never thought to use alcohol. will it damage the clear parts?
MPWR
01-29-2006, 08:37 AM
No, should leave them pristine. If there's any residual haze from the paint, it can be easily polished off.
What did you paint with?
20V_AE82
01-29-2006, 02:29 PM
tamiya paint. sprayed over with clear
MPWR
01-29-2006, 02:33 PM
Acrylic, enamel, or laquer?
20V_AE82
01-29-2006, 04:22 PM
acrylic paint. with tamiya clear gloss sprayed over the top.
MPWR
01-29-2006, 04:51 PM
Easy. Tamiya acrylics can be quickly and safely stripped with any number of things. Window cleaner, automotive cleaner/degreaser, and alcohol will all work very well. Go to a grocery store, get a bottle of 99% or 91% isopropyl alcohol, and it'll take it right off. Leave it in a covered container over night (I like the cheap reusable/recyclable leftover containers, also at the grocery), and the plastic will be as clean as when you started the kit.
20V_AE82
01-29-2006, 05:19 PM
cool. i will give it a go. it will strip off the clear that was sprayed over the top of the paint as well?
MPWR
01-29-2006, 08:27 PM
Yes, it'll take the clear off too. If it's laquer clear, it may protect the paint undernieth it for a little while, but the alcohol will take it off. If the clear is acrylic, it will all come off pretty quickly. Isopropyl will even strip Tamiya primer.
