Headlights keep blowing up...
therock6000
01-27-2006, 11:16 AM
My right headlight keeps deciding to blow up. I've changed it twice, but it keeps happening. What do i need to do to fix this? Thanks.
Stevo2
01-28-2006, 12:39 AM
What year, model, engine? Could be a bad ground, connector, etc.
RahX
01-28-2006, 04:19 AM
first off, dont touch the glass. second, is there any moisture in the headlight? how tightly do they sit in the housing? touching the glass can leave fingerprints which can make the glass heat up at diff temps and cause em to crack. moisture can crack hot glass in a split second. those bulbs arent very risilient in the presence of vibration.
therock6000
01-30-2006, 07:48 AM
Its a 95 Ram 1500 with the 5.9L. I didn't even think about the possibility of moisture in headlight itself. I'll definitely check that out. Also, where would it be grounded at? I really appreciate the responses.
Stevo2
01-31-2006, 07:26 PM
G105 is the ground for the L/H light.
http://pic17.picturetrail.com/VOL856/1102933/2077148/127888450.jpg
G102 is the ground for the R/H light.
http://pic17.picturetrail.com/VOL856/1102933/2077148/127888401.jpg
therock6000
02-01-2006, 07:53 AM
I can't thank you enough!
