91 tracker Check engine light.
viperh
01-27-2006, 08:43 AM
So It idles (check engine light) It goes out as soon as I hit the gas. If i push the accelerator at a stop or cruising the light goes out. As Soon as I let off the gas it comes back on.
If I downshift and get the rpms back up without the foot on the gas the light is on.
I have a small exhaust leak in front of the o2 sensor. I'm thinking it is either the o2 sensor reading something fubar'd becuase air is getting in the exhaust at that leak or maybe the TPS is going out. I have a new gasket for the exhaust when it warms up I'll put it on.
Anyone else have this problem?
Nate
viperh
01-27-2006, 02:11 PM
Nate
Nevermind I fixed it, The oil was dangerously low... I apparently have developed a gushing leak where the oil pump mates to the block.:banghead:
viperh
01-28-2006, 05:45 AM
I lied it didn't turn off the check engine light.:banghead:
brokenantimatter
03-10-2006, 11:23 AM
you might have to have it reset
trackerguy
04-05-2006, 10:07 PM
The check engine light on a 95 Tracker is inside the left front speaker on right inside hole, its a slide switch. It might be in the same location on your 91
viperh
04-08-2006, 05:53 AM
Oops.. I didn't update it.. My TPS went bad. Replaced it an viola it ran.
