swaps 90 dx body gettin done ...
Baumann_Yayo4G
01-26-2006, 03:27 PM
ok guys , i have a 1990 civic dx in the shop right now an im contemplating wether to put a b16 or a b18 into it now if i go with the b-18 im going to put the b 16 vtec head on it, but this was an idea i heard about ..called the frankenstine, is it? but i don't no im thinking which one would be easier i no the b 18 an b16 is a tough one btu would the b16 fit in without engine mounts needed an if not wut other dohc engine could i fit in it?...this is my frist project an im working with an machanic that is used to the older mucle cars an fixing newer ones but not a complete rebuild right now w're starting on the suicide doors an body widening kit then the engine then paint so im jus wondering wether to use the b-16 full or b18 with b-16 head an so on.. thanks guys any input would help!
turtlecrxsi
01-26-2006, 04:09 PM
Both B16 and B18 require mounts into a 4th gen civic or crx. Frankenstein or LS/VTEC requires machining and custom fabrication to get it to work... not to mention tuning. You can "SEARCH" these topics and read about it forever.
Baumann_Yayo4G
01-26-2006, 07:16 PM
thanks alot for that info in ur opinion wut engine should i put in my dx i'm just looking for a powerfull engine that'll really move i've got a turbo an i will be gettin different things for hp improvment i've got my ideas for the look an eny way i want it i got it i've done some extencive construction work for a mechanic an for pay he's doing my car.....but i need soem engine ideas ...wut would fit but with max power an a strong enough block to hold a turbo an futrue mods!! thanks again
FuLL BLown STD
01-27-2006, 03:55 PM
If your wanting to do turbo.. i recommend just getting a b18a/b.. fairly low compression motor that seems to take boost with no problem.. if your deiciding to do turbo ls/vtec which is the route ive taken.. its gonna involve alot of tuning and aftermarket internals if u plan on running high boost.. its been whole in my pcoket with this build up but will be pretty wicked.. and yeah u will need some custom mounts.. theres a few different mounts ranging from ebay cheapies to hasport billets.. like $200 to $500.. oh yeah and if u havent done the dpfi to mpfi.. maybe u oughta look into that first "mpfi conversion" b18a/b stock internals..open differential, fuel/spark mgmnt, and u can see 12's if tuned right:iceslolan
Baumann_Yayo4G
01-28-2006, 10:06 AM
ok thanks guys for the details ill get back to ya in a bit ok take it easy till then!!
