P0751 - 1-2 Shift Solenoid Valve Performance - No First or Fourth Gear
ern2112
01-24-2006, 10:06 AM
I knew I was having trouble with my tranny solonoid a......getting ready to dig into it.....thing that I wonder is why does the code say no 1st or 4th gear. The only gear I am having trouble with is 2nd......whats up with my box the 1st and 4th thing?
ern2112
01-24-2006, 10:08 AM
Sorry...it's early..should have said....
..whats up with the 1st and 4th gear thing?
BNaylor
01-24-2006, 10:42 AM
The PCM is detecting the solenoid is not performing properly. According to my ATSG guide for the 4T65E tranny P0751 which is a class "B" DTC error code indicates 1 - 2 Shift Solenoid Performance problem. All shift solenoids work as a logic gate based on the signals received from the PCM. One not working could conceivably affect other shifting, etc.
P0751 does the following:
It disables shift adapts.
Commands maximum line pressure.
Inhibits 3 - 2 downshifts when speed is greater than 30 mph
Basically the 1 - 2 shift solenoid is sticking in the off position and should be replaced.
ern2112
01-24-2006, 11:26 AM
Thanks Bob....kinda figured it was what we already knew. You have almost got me talked into doing this myself. How much is that solenoid....and should I go ahead and do anything else while I am in the tranny? Oh......what about part numbers so I can order the stuff?
