type r fuel & timing settings.... help
crabby760
01-23-2006, 12:37 AM
i got a jdm type r swap with intake/header/exhaust... fuel pressure reg and a p28 with mugen chip "RICH"
wat would be a good fuel setting rite now its at 55 psi at full throttle
and my ig timin is at 15 degree
was thinkin of droppin fuel to 30 psi and advancing like 3 or 4 degrees... wat do yall tink...
anyone have simliar set up and know whats good
TurboGSR96
01-24-2006, 07:18 PM
i wouldbt drop the fuel pressure that low, i believe stock fuel pressure is in the high 40 or low 50's. as for the timing just call an acura dealership to make sure you get it right. did you try to check the fuel pressure with the vacumn line disconnected? i think that is the proper way to do it.
superbluecivicsi
01-24-2006, 11:32 PM
throw out the chipped ecu and put the fuel pressure back to stock. then you are fine ;)
