oil temp gauge dont move
boyertownMidnight
01-22-2006, 09:38 PM
my oil temp gauge (92 GS) dont move at all, is there any fuses or relays i should check?
thanks,
SLoe
01-22-2006, 09:52 PM
Make sure the wire is connected at your sending unit.
Bodack
01-22-2006, 10:32 PM
Unless you have an aftermarket oil temp gauge installed, you don't have one. You have oil pressure and water temp. Which one are you talking about? Water temp, the wire probably just came unhooked or broken at the thermostat. There are a few wires in a little harness that connect to the thermostat. Just check and see if any are off.
SLoe
01-23-2006, 04:40 AM
He is right, I wasn't paying attn. I thought you said oil pressure. :icon16:
boyertownMidnight
01-23-2006, 08:32 PM
nah its a gauge i got a temp gauge for my coolant, a tach , and speedometer, and a oil guage. it says oil on it, so where should i look ?
SLoe
01-24-2006, 11:16 AM
Like I said, find your sending unit (probably somewhere near the filter) and make sure the wire is connected. You should go buy a repair/maintenance manual as soon as possible. You will need it.
Pedro F
01-24-2006, 09:56 PM
the sensor is located right next to the crank pully or behind it i should say.
Pedro
