1984 bmw idle prob?i think
cos3
06-17-2002, 08:54 AM
i have a problem with my idle
my car runs good when first started but when it warms up the idle drops down to low....:mad: then the oil presure light comes on and off flickering
as soon as the gas is implied it goes out
no lose of power or nothing i'm confused\
can anyone help with some ideas
if idle is to be rest by dealer any idea on cost
thanks christian
cos3
07-06-2002, 11:51 AM
my car when idling for a period of time....the temp..raises high
it's never over heated yet but i think it might....?
any help?
thanks christian:confused:
dc_caron
07-21-2002, 07:25 PM
I have a 733i with all kinds of problems, mostly electrical, what ever you do fix the problem yourself, a mechanic is going to charge an arm and a leg, and a kidney. I'm trying to locate a owners manual, do you have one, also do you have a complete set of tools in the truck, aparently you can fix any problem the car has with the tools in the truck and the owners manual, send a message back [email protected] I'm trying to get in comntact with as many 733i owners as possible. thanks
cos3
07-22-2002, 06:58 AM
:bloated:
yeah i have a 733i and the owners manual
but it don't tell me shit
i went out a bought a repair manual too...still no help
it says i need a speacial tool not in the tool kit
shit everything is so difficult...
need some info hit me back
dc_caron
07-22-2002, 09:31 AM
what repair manual do you have? do you want to sell your owners manual? is the special tool you need is it the CO meter? How are the spark plugs and distributer cap? If your ignition wirering is coroded that plays a significant role. if their isn't enough air flow to the engine it will have an incomplete combustion hence high CO levels. This problem you have could be either very simple to fix if you simplify the question. let me know what youve done and whats good, then we can eliminate the complexity of the problem.
bigsix
08-04-2002, 09:00 PM
if anyone needs a (etm) electrical trouble shooting manual , i have a copy that i am going to make into a pdf file. i am also very knoledgable on e23 motronic systems . i would be more than happy to help anyone out.
mark
newbe
12-07-2002, 07:27 AM
check hollow oil feeder bolts on cam oiler rail. if loose they can cause low oil pressuraidle//of course oil sensor itself if leaking-replace it//adjusting valve lash and throttle sensor position may help idle speed.
good luck
Jimwestover
05-25-2003, 05:25 PM
We have the Answer for all BMW Electric Windows you can Fix all of them
and sunroof in under 2 hours correctly and Professionally.
Do your windows roll down and not up or work part of the time?
Do your windows have a mind of there own?
Well not anymore Redline BMW Repair Has a do it yourself video Software that we guarantee will fix this problem in all BMW's
We also rebuild BMW Switches with a one year Warranty Call for Pricing
Jim @435-467-0429
We will have a website with aftermarket Performance & parts for the 7 Series Soon!
isa369
06-10-2003, 01:33 PM
i think the air auxilary valve need to be checked .. this located under the intake manifuld..
