700R4 and 200R4 for your PMD engine, or BOP
ramairgto72
01-21-2006, 08:59 AM
I have a TH400 under my Pontiac and I love it, but the only problem I see with it is that I allways want to grab another gear. So in the section i'm going to point you in the right direction in to fitting a 700-R4 or a 200-4R in your Pontiac. First off as some of us know, the 700-R4 in a "CHEVY" only bolt pattern, this is only a problem for somone who does not want to spend 60$ on the adaptor found in any SUMMIT book! Also the 700-R4 may not fit well in a F body dew to its wider then TH400 or TH350, so unless you want to pound and or cut your floorboards the 700-R4 may not be good for your F body.
You can also go for a Gear Venders overdrive, but the price is rather high, so unless you got 3 large look below for some good ides.
NOTE: The 700-R4 is based on the TH350
NOTE: The 200-4R is based on the metric TH200
NOTE: The 200-4R will fit A-body and F-body and most have the B-O-P pattern
NOTE: The 700-R4 was upgraded in 1987, so look for a 87 up 700-R4
NOTE: The 200-4R with upgrades will not take high torque engines!
NOTE: The 200-4R also came in NON-OVERDRIVE, mostly in big cars
NOTE: The 200-4R and 700-R4 use a TV cable that will have to be hooked up like a TH350 kickdown cable
NOTE: The 200-4R and 700-R4 will need aftermarket stuff ( see Level 10 below)
NOTE: The 200-4R Gearing is 1st 2.74, 2nd 1.57, 3rd 1.00, 4th .67
NOTE: The 700-R4 Gearing is 1st 3.06, 2nd 1.63, 3rd 1.00, 4th .70
Hollander interchange codes for the 200-4R 1883A Buick, Olds. Pontiac bellhousing bolt pattern
1883B Chevy only bolt pattern
1883C Multi-bolt pattern bellhousing
Where to Find a 200-R4 Transmission YEAR MAKE MODEL COMMENTS
'83-87 Buick Regal, Somerset 231 V6
'83-87 Buick Grand National, T-Type Turbo 231 V6
'87 Buick GNX Turbo 231 V6
'81-90 Buick Electra, LeSabre, Limited 231 V6, V8
'81-90 Buick Park Ave, Ultra, Estate Wagon 231 V6, V8
'81-82 Cadillac DeVille, Fleetwood, Limo V6,V8
'86-90 Cadillac DeVille, Fleetwood, Limo V8
'86-90 Cadillac Brougham 307 V8 only
'84-88 Chevy Monte Carlo SS 305 V8
'84-88 Chevy Monte Carlo 305 V8
'84-88 Chevy Malibu, El Camino 305 V8
'81-82 Chevy Caprice, Impala Assorted V8s
'86-90 Chevy Caprice, Impala Chevy V8, Olds 307 V8
'81-90 Chevy Caprice Wagon 307 V8 only
'84-87 Chevy GMC Sprint 305 V8
'83-88 Olds Cutlass 307 V8, 231 V6
'83-84 Olds Hurst 307 V8
'85-87 Olds 442 307 V8
'81-90 Olds Custom Cruiser Wagon 307 V8
'81-90 Olds 88, 98, Regency 307 V8
'81 Pontiac Catalina, Bonneville V8
'84-89 Pontiac Parisienne, Safari Wagon Olds 307 V8, Chevy V8
'84-87 Pontiac Grand Prix 231 V6, Chevy 305 V8
'89 Pontiac 20th Anniversary T/A Turbo 231 V6
Note: all above are rear-wheel drive, Some of the above may not have 200-R4!
For Parts and or Kits contact :
Level 10 Installation Center
188 Route 94 North
Hamburg, NJ 07419
201-827-1000
