timing set and engine verification
superman3405
01-21-2006, 12:00 AM
Does anyone knwo how to tell what year an engine is? I have looked over the block and cannot find any id numbers, am I not looking in the right place? Also what is standard timing setting for a stock 350 engine?? The engine is in a 72' chevy truck. any help would be appreciated. Thanks!!
2000CAYukon
01-21-2006, 11:25 AM
You need to find the casting numbers on the block. Read this link to find out where they are and which engine you have: http://www.mortec.com/castnum.htm
//2000CAYukon
//2000CAYukon
777stickman
01-21-2006, 03:46 PM
Timing should be anywhere between 4 to 8 degs BTDC with vacuum hose disconnected to the distributor and plugged. Casting #'s are usually cast into the back of the block(very hard to see). Serial #'s are stamped on a flat boss just forward of the right side (passenger) head.
