Removing '97 brake light cover
MCVL
01-17-2006, 09:25 AM
How do you remove the brake light cover so I can install a new bulb? I didn't see any fasteners, etc?
bryfry
01-28-2006, 07:40 PM
MCVL, it's pretty straight forward. Open the rear doors/hatch and you will see two holes on the inner door jam: one above the upper hinge and one below the door strap. Using a flashlight you will see the two phillips head screws that hold the light assy. in place. If you have a magnetic screwdriver it will be easier due to the probability of dropping the screw inside the jam. Remove those two screws and the unit just pulls out.
