starting problem
Michael A. Jones
01-13-2006, 11:25 AM
my 98 I-30t won't start battery good everythings seems ok, when U turn the key the clock goes off, like the ground was disconected. This problem happened about 2 weeks ago I played w/the ground wire and it worked fine until now. Please any suggestings please? One more thing the car does not turn over thats why I think ground problem.
Nahkapohjola
01-13-2006, 12:14 PM
- Check gnd wire chassis attachement condition (usually under batt tray).
- Alt connectors oxidized - no charge, batt empty.
Michael A. Jones
01-14-2006, 11:12 PM
THANKS for getting back to me, my problem was the internal ground at the starter. Repaired wires starts fine.
Michael A. Jones
01-14-2006, 11:30 PM
have new problem 2000 nissan altima fuel system will not pressurize? change fuel water seperator still no pressure.
Nahkapohjola
01-15-2006, 02:31 AM
Possibilities are:
- Tank Empty,
- Pump: dirty, broken, no supply voltage (fuse, loose connector, broken wire)
- Fuel hose broken, blocked, collapsed, pinched
Worst case: need to take pump out for inspection
- Tank Empty,
