camry 1997 engine code P1780 ?
WOUNDUP
01-10-2006, 03:49 PM
What is the meaning of this engine check code for 97 Camry - P1780
csaxon
01-10-2006, 04:38 PM
Park/neutral position switch malfunction. Signals are scrambled to ecm from the position switch. Could be a circuit short, a bad switch, or bad ecm.
Brian R.
01-10-2006, 04:57 PM
Brian R.
See the following posts for corrections to diagram:
http://i16.photobucket.com/albums/b8/rogersb/DTCP1780-2.jpg
csaxon
01-11-2006, 11:54 AM
The dtc illumination conditions (rpm and speed), trouble shooting procedures and values have changed from what you posted.
Example Inspec Procedure 1 shows shift position P with continuity checks of terminal 6-5 and 4-7.
The gen 4 tests terminals 6-5 and 2-7.
It gets you looking in the right area though.:smile:
Brian R.
01-11-2006, 05:34 PM
Thanks for the correction. Is that the only error in the troubleshooting diagram?
csaxon
01-12-2006, 10:29 AM
L is 2-3 for gen4 vs 4-3
P or N is 0v instead of 0-3v
Another scenario if you have the engine immobilizer system because harness is different.
etc etc.
etc etc.
Brian R.
01-12-2006, 05:32 PM
Great! Thanks alot.
