k1500 4wd not working properly
chevyman4life88
01-08-2006, 11:48 PM
Ok so I own a 88 chevy k1500 and the 4wd dosent work properly. i have been having a hard time diagnosing the problem so i am hoping some1 will be able to help me out.
When shift lever is in the 4wd position, in either 4 hi or low, it doesen't always engage, or when shift lever is in 2wd the 4wd will engage and the front drive shaft will spin without being locked into 4wd
I have tested the actuator in the front differential, replaced the switch on the T-case and checked for power at the connections. I dont know were to go with it next any ideas on what it could be?
robertjr
01-23-2006, 04:50 AM
Sounds like you need to realign the shifter. Not sure what the exact procedure is on yours. what model transfer case do you have?
