94 turbo engine and tranny
EDMUND65
01-05-2006, 05:36 PM
what mods have to be considered installing a gst motor in my talon... from a 94, besides mounts, wireing, tranny, dash.... motor mounts? a friend has one that he might be selling ,me... it comes with a tranny too 5 speed
defiancy
01-05-2006, 05:45 PM
I don't even think your mounts are different. You are essentially putting the same motor into your talon that was in there before +a turbo.
So you will probably need an ECU from a GST or TSI, and maybe a turbo wiring harness. Other than that I think everything bolts right up.
EDMUND65
01-05-2006, 06:17 PM
SWEET! what shuould i look for on this motor when im gunna buy it? i dont know price yet... but i think it has 50 or less K miles on it...
defiancy
01-05-2006, 06:24 PM
If it's already out.
Look for any cracks in the block or heads, any place that is leaking oil excessively.
Before you put it into your new car I would advise taking it apart and replacing all the seals for the heads, valve cover and what not.
Check to make sure all the sensors are good.
Also might be a good time to replace all the lifters, and you can get some better oil squirters if you want.
This is also a good time to change cam gears or do any upgrades to the engine itself.
Thor06
01-05-2006, 07:09 PM
Definately do a compression test if at all possible. I wish we would have done that on Mikes car, we would have been able to get it for lots cheaper. I think whoever post above was right, a 4g63nt and a 4g63t uses the same engine mounts and I would assume the harness, but you might need one of those. I think all you would need is the ECU. Is the fuel pump in the NT going to be able to keep up with a turbo engine?
defiancy
01-05-2006, 08:00 PM
I think the fuel pump is the same in the NT as in the turbo, I know the injectors in the car are different.
But I'm not 100% sure in this case.
Hell it could use a walboro 190 anyway ;)
EDMUND65
01-06-2006, 12:42 AM
dduude 100$ and the interrior from my parts car and the turbo engine and tranny wirein g harness and ecu with 32k miles is mine!!!
subsrmything
01-11-2006, 02:15 PM
i have a 1996 eclipse
i put two turbos in it
changed the suspension
and it flys
and it flys
clarky99_69
01-11-2006, 05:53 PM
Change your fuel pump put in a better pump, this should have all the info you need to make an N/T into a turbo http://www.vfaq.com/FAQlocator-index.html
Thor06
01-11-2006, 10:08 PM
and it flys
And that has what to do with the topic at hand?
EDMUND you BASTARD!!! That is one hell of a deal man, fuck you. ;)
and it flys
ez1286
01-11-2006, 10:29 PM
and it flys
Two turbos? I call bs. LIAR!!
and it flys
Blackcrow64
01-11-2006, 11:23 PM
It's possible if its a sequential turbo setup...
But I doubt he has it. Let's see some pictures to back it up, subsrmything... :wink:
