Speedometer Cable Release
Vlodomyr
01-03-2006, 09:40 PM
I can't find it..........augh. 84 z-28
I've got everything outta the way/off except for the speedo cable. Just a general area and what it looks like will help alot, and maybe a good tool to use.
Morley
01-04-2006, 01:02 PM
It is a metal spring clip on the cable head, has a tang sticking out. Push it towards the speedo with a screwdriver and pull the cable off at the same time.
Vlodomyr
01-04-2006, 08:46 PM
Ok thanks alot, how about size on the speedo?
I'm guessing about 5
***EDIT***
Nevermind, how hard would it be to get a different speedo of the same size into the same spot?
Morley
01-05-2006, 01:37 AM
Difficult because of how the speedo mounts. Unless you just want to go with a speedo from a different Camaro...say one with a 140 speedo, that should bolt right in place.
Vlodomyr
01-05-2006, 06:35 AM
K thanks alot this has helped me out in a big way
