Carb And Intake
trvsglr
01-02-2006, 04:07 PM
Look for a carb and intake cheap cause im poor for my 85 Delta 88 royale 307 thanks!
maxwedge
01-02-2006, 04:47 PM
What does this mean, you don't already have one, explain this scenario/question better! Try a local salvage yard?
trvsglr
01-02-2006, 11:20 PM
I don't know my cars messed up it runs for a little then it will feel like its starving for gas and shuts off. We changed the filter and fuel pump and everything like that. I even put a different carb. on it and that didn't work either. When it was about to stall my bro dumped gas in the carb and it tried to stay runnin. But my siss's boyfriend said it might be something with the float bowls and if i got a different carb. and intake it would work fine. Think it would??
maxwedge
01-03-2006, 08:56 AM
This is not your problem, could be the filter in the tank blocked, you need someone familiar with diagnosising a problem like this to look at it, not replace major parts that are not the problem. Remember there is also a fuel filter in the carburetor inlet fitting.
auto trainy
01-03-2006, 07:20 PM
You may have bad fuel.
