p0147 code
666_speed
01-01-2006, 02:56 PM
my ses light came on and had it scanned and got the code P0147 - HO2S Heater Circuit Bank 1 Sensor 3...which would explain why my ac doesnt get very cold and my heater gets so hot it will actually blister you if you put your hand infront of the vents for 15 seconds lol....dont ask how i know......my question is where exactly is this located and will it hurt anything to leave it? thanks!
MT-2500
01-01-2006, 03:56 PM
Last sensor back on bank 1 bor the bank with cyl one.
Depending on year and engine but sensor 3 is usually the one behind the cat or last one back.
It is not a 02 sensor bad code just the heater [circuit] on it.
Check wiring to 02 sensor heater circiut and plugin and fuse.
Like power to the 02 sensor heater circuit.
But a 02 sensor is a long ways from a air cond or inside car heater problem.
MT
666_speed
01-01-2006, 07:14 PM
sorry its a 98 3.8l....and thanks a ton for your help...i'll check it out tomorrow.....oh and if its not fixed will it be a problem? thanks again
MT-2500
01-01-2006, 08:22 PM
Not sure how or if it will affect it.
But the light may stay on and if some other major sensor problem happens you will not know it unless you read the codes.
Also it will not pass emissions inspections with light on.
Good luck MT
666_speed
01-01-2006, 08:28 PM
i went to autozone and had the code ran and cleared and the light hasnt come back on yet...dunno if it should or not tho...thanks
MT-2500
01-01-2006, 08:41 PM
If it cleared and has not came back on it is not acting up\or bad now.
If the problem comes back it will trip the light.
Good Luck MT
666_speed
01-01-2006, 09:02 PM
ahh cool...it came on the other day when i was idling and stayed on until it was cleared and i havent seen it since...luckily i dont have to worry about passing emissions tho...thanks again for your help!
