'97 Ply. Grand Voyager problem Start
karpie
12-31-2005, 08:28 PM
My Name is Carlos
First of all I request excuses, I am of origenes Hispanic and I have problems with the Ingles language for that reason to write this message I have I throw use of a translator.
I have Van Ply. Great Voyager of 1997. for some months I have been coming having problems in the starting, when I open the contact, assumes that it must ignite all the panel and is not asi I do not have ningun indicating in the panel, manages to start but to the 3 second problem is extinguished to the east motor estube solving disconnecting bateria to him or clearing the memory fuse to him, but not always it is solved this way, it been able to be hours, day or weeks without starting but of a little while to another one alarma)Ya takes. some mecanicos relate the problem to the security system (that when it buys goes it of USE did not give ningun remote control to me of alarm. This is not everything in several ocaciones I have been leading and all the indicators of the panel (gasoline, temperature, millaje, the accountant of miles and the airspeed indicator) but the car fall continues walking this problem of ingual way can last day and in ocacione the car if it starts and of equal way as ocurrio the promotto is corrected from a little while to another one. Ojala that somebody of You of you can help
Carlos
Thank you very much.
Mi Nombre es Carlos
Ante todo pido disculpas, soy de origenes Hispanos y tengo problemas con el idioma Ingles por eso para escribir este mensaje he echo uso de un traductor. Tengo una Van Ply. Gran Voyager SE de 1997. hace algunos meses vengo teniendo problemas en el arranque, cuando abro el contacto, se supone que debe de encender todo el panel y no es asi no tengo ningun indicador en el panel, logra arrancar pero a los 3 segundo se apaga el motor este problema lo estube solucionando desconectandole la bateria o quitandole el fusible de memoria, pero no siempre se soluciona de esta manera, puede estar horas, dias o semanas sin arrancar pero de un momento a otro arranca.. algunos mecanicos relacionan el problema con el sistema de seguridad (alarma)Ya que cuando compre la van de USO no me entregaron ningun control remoto de alarma. Esto no es todo en varias ocaciones he estado conduciendo y se caen todas los indicadores del panel (gasolina,temperatura,millaje, el contador de millas y el indicador de velocidades) pero el carro sigue andando este problema de ingual manera puede durar dias y en ocacione el carro si arranca y de igual manera como ocurrio el prolema se corrige de un momento a otro. Ojala que alguien de Ud. de pueda ayudar
Muchas gracias
Carlos.
Carlos
Mi Nombre es Carlos
Muchas gracias
Carlos.
