shifting problem help!
sandram
12-28-2005, 07:47 PM
1986 t-bird drove home ok pulled in parking area put in rev. then to return into drive no luck arm in collum will only let me go into rev.& netural any idea's
overl0rd
12-29-2005, 12:20 AM
Something in the linkage is probably rusted frozen. Take a look at it and hit all pivots with some pb blaster.
sandram
12-29-2005, 01:18 AM
ok will try & let you know update
sandram
01-06-2006, 07:03 AM
well no help can it be a problem in steering collum or is there a brake sensor by back of pedal to be changed or should i look in the steering collar what can it be i also was told maybe a netural safety switch
or try turning key part way shifting and starting with it in netural &
brake on i could use any advice please
97Bird
01-06-2006, 12:07 PM
If you remove your off topic post from the Tech Help thread it would be appreciated and the help you need may show up here.
