91 camaro not starting
jinwern31
12-24-2005, 11:28 AM
Please help
My 91 camaro rs is not starting. When I turn the key to start it, the warning lights do not come on. The battery has a charge because the dome light and head lights still work. The starter is not being engaged so I doubt it is that. Anyone know what it could be?
Thanks
Thanks
ROUDA
12-24-2005, 11:47 AM
Is it clicking when you turn the key?
Genopsyde
12-24-2005, 12:04 PM
does the security light come on?
88camaroproject
12-24-2005, 12:25 PM
umm does the fuel pump pressurize? can you hear the starter spin? does it click, are the headlights bright? or just on.
jinwern31
12-24-2005, 01:16 PM
Their is no clicking sound when I turn the key. I don't know about the security light. Is it in the dash with the rest of the warning lights? If so then it is not on.
The starter is not spinning, but I am not sure about the fuel pump. I can check it later today.
The dome light and the head lights are at regular brightness. I recharged the battery, so it should have plenty of power.
Thanks
Jinwern 31
Thanks
Jinwern 31
88camaroproject
12-24-2005, 02:41 PM
sounds like a fuse or a wiring problem, or a relay
88camaroproject
or your ignition is messed up, like where you put the key in
scott07422
12-30-2005, 02:48 PM
Thanks
Jinwern 31
i have the same car its the VATS thats what happends on my car sometimes it takes 10 min once i sat there for 60 min so now i kept two sets of keys with me but it sucks? they want $400 to replace it
i had the car for two years only 3 times it happend to me so for i cant find some one that will bypass the vats i think the part is like $10.00
Thanks
Jinwern 31
jinwern31
12-30-2005, 04:15 PM
Thanks for your help everyone
It ended up that their was a broken wire at the starter. Fixed that and their was no more problems.
