Help, Guys!
SG007
12-23-2005, 03:23 PM
I was driving home from work today when all of the sudden I tried to accelerate and i heard this real loud knocking sound and the car wouldn't go anywhere. It doesn't stall, and if I go real easy on the gas it's fine, but when I accelerate normally it seizes and knocks! What the hell is it!? It scared me....you can only imagine the traffic I was in. God I almost had a heart attack. If you guys have any ideas please tell me....
jcurrieirocz
12-23-2005, 03:45 PM
hows your oil is there any?? doesnt sound like you sould move it much..... you dont here it slaming ones or twice do you is it constiant...if not it may be a broken tranny mount if not sounds like your engine
maybe a bad exhust leek?? also not sure
FormulaLT1
12-23-2005, 04:17 PM
Yup, check oil pressure first. If its just a knock when you first accelerate and slow down. It could be U-joint , tranny mount or rear issue but from the sound of it. It sounds like a major engine issue such as a spun bearing.
SG007
12-23-2005, 06:51 PM
She's got fresh oil, I changed it yesterday. I checked the plug and the filter, no problems.....If I hit the gas easy it doesn't happen, only when I slam my foot down.
FormulaLT1
12-23-2005, 06:57 PM
not oil,as in clean. Oil as in pressure. How much oil pressure is she making cause I actually spun a bearing on my original engine in my car. The same exact day I changed the oil in it. So that doesn't really always matter as much as some people think.
KaotiKCamaro5
12-24-2005, 01:11 AM
i had a similar problem with my camaro one time, when i accelerated anywhere near hard, there was a loud knock and the car sputtered hard.. replaced the o2 sensors, no more problems.
Morley
12-24-2005, 03:18 AM
Sounds like the trans mount is broken and the trans is hitting the tunnel when you tromp it.
Get under the car with a jack and jack up the trans by the tailshaft, look to see if it lifts off the trans crossmember mount at all, if it does,,,get a new mount.
1986Z28
12-24-2005, 03:39 PM
check to see if a con rod is sticking out the side of the block... jkjk probally a tranny mount or sumthing
SG007
12-24-2005, 04:20 PM
Very funny, lol.
