Check Engine Light!!
civicblumagik021
12-23-2005, 01:33 AM
Ok my car's check engine light is on, so i take my car to my friends house because he has an obdII diagnostic scanner and it said i was throwing a code that had something to do with a fuel issue...i was wondering if i could be running kinda rich or lean. when car is running, ehaust fumes smell very rich... what could this be?...and can a DSMlink tune the car and fix the problem?
Turbodog97
12-23-2005, 01:48 AM
Um...do you have the specific code it threw, that's kind of necissary to diagnose your problem. I noticed in your picture you didn't have a recirculated bov. Your car could be running rich in between shifts which could cause the rich smell and I think that can throw a CEL also.
civicblumagik021
12-23-2005, 01:55 AM
No im not sure i'll find out asap and post it...
Turbodog97
12-23-2005, 01:23 PM
Also what psi are you running on your evoIII?
civicblumagik021
12-23-2005, 05:38 PM
don't have a boost controller yet... :(
blk_srt
12-24-2005, 04:05 PM
How about a boost gauge?
civicblumagik021
12-24-2005, 05:14 PM
yes i have the stock boost gauge
Turbodog97
12-24-2005, 09:18 PM
So in no way is the Evo III's boost being controlled? And you aren't sure how much boost you are boosting? :confused: Que malo!!! That's most likely your problem right there.
blk_srt
12-25-2005, 12:06 PM
probably leaning out
