new brake stuff
Skylindrftr
12-20-2005, 09:40 PM
I went to d1gp and picked up some new front pads for my car for 60 bucks, they are old hks pads, i am guessing at least 5 years if not older, b/c hks hasnt made pads in awhile, but they are brand new!
I also went down to rrr and got some nismo brake lines for the front...
I havent gotten a chance to work on my car's brakes before, so how would I go about installing these parts...thanks
iknow ill probably have to bleed the lines etc...but for the pads ive seen people put stuff on the back of them when installing, what is that stuff?
http://img418.imageshack.us/img418/550/dscn21721zi.th.jpg (http://img418.imageshack.us/my.php?image=dscn21721zi.jpg)
http://img418.imageshack.us/img418/7016/dscn21736wq.th.jpg (http://img418.imageshack.us/my.php?image=dscn21736wq.jpg)
http://img418.imageshack.us/img418/4136/dscn21772qw.th.jpg (http://img418.imageshack.us/my.php?image=dscn21772qw.jpg)
http://img418.imageshack.us/img418/5490/dscn21753ku.th.jpg (http://img418.imageshack.us/my.php?image=dscn21753ku.jpg)
http://img418.imageshack.us/img418/362/dscn21741nq.th.jpg (http://img418.imageshack.us/my.php?image=dscn21741nq.jpg)
nissan_240sx
12-24-2005, 04:43 AM
-jack front car up
-remove lug nuts
-remove tires
-pop hood, remove brake fluid resivour cap
-remove 2 bolts behind caliper (top, bottom of caliper)
-remove caliper
-remove old brake pads, and brake retainers (thats what i call them. and make sure you know which pad goes where. take note on the old pads)
-use a clamp to push the brake piston in, alittle at a time. (thats why you take the brake resivour cap off)
-push piston in until the caliper can fit snug with the new pads
-clean/spray the retainers with brake fluid
-spray new pads lightly
-spray rotor
-put retainers back on
-put new pads in
-fit the caliper in
-tighten the 2 bolts
-cap the brake resivour
-keep pressing the brake pedal till you get the normal feel
repeat on the other side
For the rear brakes, use needle nose pliers to twist the piston in instead a clamp. I believe its clockwise. When i did mine, it was a bitch to get them to go in. As for the brake lines, a friend did that for me so im not too sure about that.
good luck
-Matt
-remove lug nuts
-remove tires
-remove caliper
-spray rotor
-put new pads in
-fit the caliper in
good luck
-Matt
Skylindrftr
12-24-2005, 05:20 PM
im not doing the rear yet...but thanks a lot for the info!
how do you put new lines on? (just the front)
Chuki_breath
12-26-2005, 12:00 AM
i would just look at how the stock lines are on...cant be much different lol. Never done brake lines before.
alphalanos
12-26-2005, 12:11 AM
make sure you bleed them properly. I guess for new lines I would just open the reservior and try to drain the old fluid out. then you install all the new parts, fill it with fresh fluid, close the reservior, then press the brake and open the bleed screw for about 5 seconds until fluid comes out. always check the reservior and make sure you top it off constantly, then repeat maybe 3 times to make sure all the air is out. then do it on the other side.
Skylindrftr
12-26-2005, 12:19 AM
hey as i said before i have never done brake stuff...so what does the bleed screw look like, and any recomended brake fluid?
to bleed it should i just disconnect all the lines and press brake pedal untill all is gone?
thanks
thanks
nissan_240sx
12-26-2005, 04:57 AM
http://wheelgoods.com/library/ActiveCaliper.JPG
like that, its located in the back of the caliper
good luck
-Matt
good luck
-Matt
alphalanos
12-26-2005, 09:07 AM
No everything must be connected when you bleed the brakes. AS you hold down the brake pedal, pressure builds up in the lines, then when you loosen the bleed screw, the pressure forces the air out, and also the fluid. So you need to hold the brake with the system closed to build pressure, then, still holding the brake, loosen the screw, to allow air out. I usually over do it a little bit and bleed it a few times when there is only fluid coming out, just to be safe that there is no air left.
R.W.240
12-26-2005, 03:26 PM
Speed Bleeders > *
20$ for one person to bleed a full brake system in 10 minutes FTW.
Skylindrftr
12-26-2005, 05:25 PM
can i pick up speed bleeders at kraigen (only autoparts store near where i live...)
Chuki_breath
12-27-2005, 10:32 PM
im sure you could. Just go there and ask. I think i saw auto-zone have them around here.....which is probably equivalent to what your store is where ever you are.
Skylindrftr
12-28-2005, 03:27 AM
socal man...ok im going to do them 2morrow and im getting help from a friend who knows what hes doing so thanks anyhow!
Pavlo
12-28-2005, 08:59 PM
Yeah Speed Bleedrs are worth the money. When bleeding the brakes use good fluid, that hasn't been open for long. Flush out your old one too, as it gets the moisture in with time.
Tell us the results.
Skylindrftr
12-28-2005, 10:16 PM
it appears that the pads are for jdm calipers so they didnt fit so whatever...
but we put the lines on and they give a definate firmer pedal feel b/c they dont flex like the rubber lines...its good stuff...I also exchanged a kazama skid plate for some $ and a cusco rear strut tower bar which i will put on soon...and we turned the boost up to .8 which is the optimal setting for t25g so its all good!
nissan_240sx
12-28-2005, 10:49 PM
your car is nice btw, I want your rims lol
-Matt
-Matt
Skylindrftr
12-29-2005, 02:02 AM
hehe thanks
they are enkei mesh up front and southern ways on the back
