93 lumina 3.1 with 184,334
nobody351
12-20-2005, 07:20 PM
my car quit as i was doing 70 the oil is good it has a new fule filter and is gettin a spark on all plugs could the timing belt have sliped? or could a relay have gone the fule pump is good
meistermind
12-20-2005, 08:15 PM
The 3.1 V6 utilizes a timing chain and gears- I doubt it slipped. Mostly, 4cyl engines use timing belts. Bigger motors can have too much torque.
So......your getting spark, but you think you don't have gas (does that sound right???) Did you try spraying some starting fluid into the intake to see if it starts??? Does it sound normal during cranking- no hard cranking, or sputtering, or backfiring through the intake?
nobody351
12-20-2005, 08:52 PM
the 2 times i got it runing after it happened it ran normal and then quit no sputering, hard cranking or backfiring it quit and now i cant get it running again :banghead: please help
richtazz
12-21-2005, 09:20 AM
Your next step is to determine if you're getting spark and/or fuel. No spark could be many issues, crank sensor, ign module, computer, etc... No fuel could be a pump, relay or fuel pressure regulator.
the6
12-22-2005, 12:18 AM
nobody351 check out my post from dec. 21 you might have the same problem with the oil sending unit check for 3 wires and short the 2 opset each other see if the fuel pump comes on.
nobody351
12-24-2005, 08:47 PM
will quick steel patch a hole in a gas tank?
