Aftermarket rod and chakshaft bearings
gmcuajo
12-18-2005, 01:55 AM
When I install aftermarket rod and crankshaft bearing how is should do?
I mean about the color code of the bearings; the aftermarket comes as a set...
superbluecivicsi
12-18-2005, 05:23 AM
thats a long writeup. grab a helms. you can use jeff's writeup as reference. grab a helms along with it and you are set.
http://forums.evans-tuning.com/viewtopic.php?t=326&highlight=gsr+engine+build
gmcuajo
12-20-2005, 08:43 PM
[QUOTE=superbluecivicsi]thats a long writeup. grab a helms. you can use jeff's writeup as reference. grab a helms along with it and you are set.
QUOTE]
A helms manual says almost the same of the factory repair manual, a color codes. As the aftermarket come in standard size you most take the engine to a machine shop to do a "line-boring" job to use those stadard size bearings.
My question is if I am right or not, and if this is the only method to do it?
QUOTE]
