throwing a code
sblkcamaro70
12-17-2005, 11:27 PM
ok so my 89 lx civic started to throw code. can you tell me what one it is. what is is throwing is six quick blinks pause then seven quick blinks.
please help
please help
Savagetendencies
12-18-2005, 12:52 AM
please help
Code System
Code 1 (1 flash) Oxygen content
Code 3 or 5 Manifold absolute pressure
Code 4 (4 flashes) Crank angle sensor
Code 6 (6 flashes) Coolant temperature
Code 7 (7 flashes) Throttle angle
Code 8 (8 flashes) TDC position (top dead center) timing
Code 9 (9 flashes) No. 1 cylinder position (1.6L)
Code 10 (10 flashes) Intake air temperature
Code 12(12 flashes) No code 11 don't know why. Exhaust gas recirculation system
Code 13 (13 flashes) Atmospheric pressure
Code 14 (14 flashes) Electronic air control (EACV)
Code 15 (15 flashes) Ignition output signal
Code 16 (16 flashes) Fuel injector
Code 17 (17flashes) Vehicle speed sensor
Code 19 (19 flashes) No code 18 for some reason Lock up control solenoid valve
Code 20 (20 flashes) Electric Load
please help
Code System
superbluecivicsi
12-18-2005, 01:26 AM
sblkcamaro70
12-18-2005, 11:28 AM
so does the ecu flash when there are no codes?
livinincalifornia
12-18-2005, 01:34 PM
once when you turn the ignition on
