Code 41
Turbo1002
12-17-2005, 09:27 AM
My 1988 Delta 88 idle is high and I have a code 41. Which is a Cam sensor signal was not recieved by pcm for the last 2 seconds while engine was running. I changed the senor but nothing has changed. I reset the ecm and stil a code 41 keeps reseting. What to do next please. Thanks for an excellent boeard.
Sal
maxwedge
12-17-2005, 01:05 PM
Pull the cam sensor out and look to see if the magnet fell off the timing gear, you will need a mirror and someone to crank the engine to look for magnet, obviously disable the engine so no start is possible.
Ron AKA
12-18-2005, 04:12 PM
Replacing the magnet is kind of a nasty job. You need to remove the timing chain and gears. Another thing to check is the wiring for any bad connections.
Ron
